[geos-devel] Ready for 2.1.2 ?
Steve Lime
steve.lime at dnr.state.mn.us
Tue Jun 7 00:12:37 EDT 2005
Tests ok on OSX 10.3.9.
However, my multipolygon buffer script still produces a bus error - can someone comfirm this works in another environment? SImple polygons (w or w/o holes work fine). Multipolygon convex hulls work fine.
Steve
>>> pramsey at refractions.net 06/06/05 10:46 PM >>>
OK, compiles and runs the XMLTester fine under OS/X 10.4.1
I'm good to go. Any other test results from other platforms (windows
anyone? slowaris? freebsd? OS/X 10.3?)
cvs -d :pserver:cvs at postgis.refractions.net:/home/cvs/postgis co -r
branch-2-1 geos
cd geos
./autogen.sh
./configure
make
cd source/text
./XMLTester
Paul
Paul
On 6-Jun-05, at 2:07 AM, strk at refractions.net wrote:
> We'd like to release GEOS 2.1.2, a bugfix and performance
> improvement work.
> Changes since 2.1.1:
> - Segfault fix in Point::isEmpty
> - Mem Leak fix in OffsetCurveBuilder::getRingCurve
> - Bugfix in LineSegment::reverse
> - Added multipolygon buffering test in source/test/testLeaksBig
> - Ported JTS robustness patch for RobustLineIntersector
> - Removed useless Coordinate copies in OverlayOp::mergeZ()
> - Avoided throws by IsValid on invalid input
> - Stricter C++ syntax (math.h=>cmath, ieeefp.h in "C" block,
> ostringstream
> instead of sprintf)
> - Better support for older compilers (Polygonizer::LineStringAdder
> friendship)
> - Removed useless Coordinate copies in CGAlgorithms::isOnLine()
> - Added support for polygonize and parametrized buffer tests in
> XMLTester
> - Fixed support for --includedir and --libdir
> - Fixed Z interpolation in LineIntersector
> - Handled NULL results from getCentroid() in XMLTester
> - Segfault fix in (EMPTY)Geometry::getCentroid()
> - Made polygon::getBoundary() always OGC-valid (no LinearRings)
> - Input checking and promoting in
> GeometryFactory::createMultiLineString()
> - Segfault fix in GeometryEditor::editPolygon()
> Did anyone other then me test the code yet ?
> It is accessible using the branch-2-1 tag of CVS.
> Any test or bug report is highly appreciated.
> Thanks
> --strk;
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
