[geos-devel] Ready for 2.1.2 ?
strk at refractions.net strk at refractions.net
Tue Jun 7 04:03:02 EDT 2005
On Mon, Jun 06, 2005 at 11:12:37PM -0500, Steve Lime wrote:
> Tests ok on OSX 10.3.9.
> However, my multipolygon buffer script still produces a bus error - can someone comfirm this works in another environment? SImple polygons (w or w/o holes work fine). Multipolygon convex hulls work fine.
It worked here on 32bit GNU/linux/gcc-3.4.3
You test case is included in the source/test/testLeaksBig.xml,
so it works on OS/X 10.4.1 as reported by Paul.
Did you get any warning at compile time ?
Are you able to run the test trough a debugger
--strk;
> Steve
> >>> pramsey at refractions.net 06/06/05 10:46 PM >>>
> OK, compiles and runs the XMLTester fine under OS/X 10.4.1
> I'm good to go. Any other test results from other platforms (windows
> anyone? slowaris? freebsd? OS/X 10.3?)
> cvs -d :pserver:cvs at postgis.refractions.net:/home/cvs/postgis co -r
> branch-2-1 geos
> cd geos
> ./autogen.sh
> ./configure
> make
> cd source/text
> ./XMLTester
> Paul
> Paul
> On 6-Jun-05, at 2:07 AM, strk at refractions.net wrote:
> > We'd like to release GEOS 2.1.2, a bugfix and performance
> > improvement work.
> > Changes since 2.1.1:
> > - Segfault fix in Point::isEmpty
> > - Mem Leak fix in OffsetCurveBuilder::getRingCurve
> > - Bugfix in LineSegment::reverse
> > - Added multipolygon buffering test in source/test/testLeaksBig
> > - Ported JTS robustness patch for RobustLineIntersector
> > - Removed useless Coordinate copies in OverlayOp::mergeZ()
> > - Avoided throws by IsValid on invalid input
> > - Stricter C++ syntax (math.h=>cmath, ieeefp.h in "C" block,
> > ostringstream
> >   instead of sprintf)
> > - Better support for older compilers (Polygonizer::LineStringAdder
> > friendship)
> > - Removed useless Coordinate copies in CGAlgorithms::isOnLine()
> > - Added support for polygonize and parametrized buffer tests in
> > XMLTester
> > - Fixed support for --includedir and --libdir
> > - Fixed Z interpolation in LineIntersector
> > - Handled NULL results from getCentroid() in XMLTester
> > - Segfault fix in (EMPTY)Geometry::getCentroid()
> > - Made polygon::getBoundary() always OGC-valid (no LinearRings)
> > - Input checking and promoting in
> > GeometryFactory::createMultiLineString()
> > - Segfault fix in GeometryEditor::editPolygon()
> > Did anyone other then me test the code yet ?
> > It is accessible using the branch-2-1 tag of CVS.
> > Any test or bug report is highly appreciated.
> > Thanks
> > --strk;
> > geos-devel mailing list
> > geos-devel at geos.refractions.net
> > http://geos.refractions.net/mailman/listinfo/geos-devel
