[geos-devel] Ready for 2.1.2 ?
Stephen Lime
sdlime at comcast.net
Wed Jun 8 03:29:21 EDT 2005
I need to replicate the test case in my environment and see what
happens. Certainly could be a coding problem in my interface.
Steve
On Jun 7, 2005, at 3:03 AM, strk at refractions.net wrote:
> On Mon, Jun 06, 2005 at 11:12:37PM -0500, Steve Lime wrote:
>> Tests ok on OSX 10.3.9.
>> However, my multipolygon buffer script still produces a bus error -
>> can someone comfirm this works in another environment? SImple
>> polygons (w or w/o holes work fine). Multipolygon convex hulls work
>> fine.
> It worked here on 32bit GNU/linux/gcc-3.4.3
> You test case is included in the source/test/testLeaksBig.xml,
> so it works on OS/X 10.4.1 as reported by Paul.
> Did you get any warning at compile time ?
> Are you able to run the test trough a debugger
> --strk;
>> Steve
>>>>> pramsey at refractions.net 06/06/05 10:46 PM >>>
>> OK, compiles and runs the XMLTester fine under OS/X 10.4.1
>> I'm good to go. Any other test results from other platforms (windows
>> anyone? slowaris? freebsd? OS/X 10.3?)
>> cvs -d :pserver:cvs at postgis.refractions.net:/home/cvs/postgis co -r
>> branch-2-1 geos
>> cd geos
>> ./autogen.sh
>> ./configure
>> make
>> cd source/text
>> ./XMLTester
>> Paul
>> Paul
>> On 6-Jun-05, at 2:07 AM, strk at refractions.net wrote:
>>> We'd like to release GEOS 2.1.2, a bugfix and performance
>>> improvement work.
>>> Changes since 2.1.1:
>>> - Segfault fix in Point::isEmpty
>>> - Mem Leak fix in OffsetCurveBuilder::getRingCurve
>>> - Bugfix in LineSegment::reverse
>>> - Added multipolygon buffering test in source/test/testLeaksBig
>>> - Ported JTS robustness patch for RobustLineIntersector
>>> - Removed useless Coordinate copies in OverlayOp::mergeZ()
>>> - Avoided throws by IsValid on invalid input
>>> - Stricter C++ syntax (math.h=>cmath, ieeefp.h in "C" block,
>>> ostringstream
>>> instead of sprintf)
>>> - Better support for older compilers (Polygonizer::LineStringAdder
>>> friendship)
>>> - Removed useless Coordinate copies in CGAlgorithms::isOnLine()
>>> - Added support for polygonize and parametrized buffer tests in
>>> XMLTester
>>> - Fixed support for --includedir and --libdir
>>> - Fixed Z interpolation in LineIntersector
>>> - Handled NULL results from getCentroid() in XMLTester
>>> - Segfault fix in (EMPTY)Geometry::getCentroid()
>>> - Made polygon::getBoundary() always OGC-valid (no LinearRings)
>>> - Input checking and promoting in
>>> GeometryFactory::createMultiLineString()
>>> - Segfault fix in GeometryEditor::editPolygon()
>>> Did anyone other then me test the code yet ?
>>> It is accessible using the branch-2-1 tag of CVS.
>>> Any test or bug report is highly appreciated.
>>> Thanks
>>> --strk;
>>> geos-devel mailing list
>>> geos-devel at geos.refractions.net
>>> http://geos.refractions.net/mailman/listinfo/geos-devel
