[geos-devel] non precision related geometric issue
strk at refractions.net
Tue Jun 21 04:34:11 EDT 2005
On Mon, Jun 20, 2005 at 08:02:49PM -0400, Carl Anderson wrote:
> Based on recent improvements in the geos library, I have started in
> depth geometric testing.
> Thanks to all for the improvements.
> attached is a test file for XMLTester for a failure case.
> The B object has an edge intersection with itself, violating assertions
> 2.1.12.1 and 2.1.12.2 of the SF SQL spec. GEOS reports it as valid but
> upon intersection it abends. JTS/GEOS is not conditioned to test for
> those assertions but Martin may have had those assertions in mind when
> writing the overlayOp bts.
That's an error in XMLTester, swap A and B geometries and you'll
read two 'false' from isvalid. 'arg1' is not honourated !
I'll take a look at it.
--strk;
> This is not a precision issue as can be clearly be seen from the test file.
> There is another variation of this issue that I cannot, as of yet,
> reliably express with a simple test case.
> The variation invloves shared edges between the two test objects. I
> will keep digging.
> C.
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
