[geos-devel] library link problem
strk at refractions.net strk at refractions.net
Sat Jun 25 05:44:07 EDT 2005
On Sat, Jun 25, 2005 at 10:25:54AM +0200, Michel Garand wrote:
> Greetings!
> On Sat, 2005-06-25 at 09:35 +0200, strk at refractions.net wrote:
> > On Fri, Jun 24, 2005 at 09:57:45PM +0200, Michel Garand wrote:
> > > Greetings!
> > > still no luck :(
> > > with ldconfig -v libgeos, libgeos.2, libgeos.2.1.2 still don't appear even though there are in /usr/local/lib!
> > Do you have /usr/local/lib listed in /etc/ld.so.conf ?
> > --strk;
> Yes, all other libraries there are listed.
But, did your geos library get the .so extention now ?
If they didn't (after libtoolize...) maybe you need a make clean.
--strk;
