Martin Davis writes: > This still doesn't produce the ultimate desired result of computing intersections to the full 56 bits of double precision, however. > We're working on a solution for that - will post it if and when it's done. I am sure you are familiar with this technique http://www-2.cs.cmu.edu/~quake/robust.html Cheers Norman
