[geos-devel] How robust is GEOS?
strk at refractions.net strk at refractions.net
Fri May 6 14:03:06 EDT 2005
On Fri, May 06, 2005 at 10:56:33AM -0700, Martin Davis wrote:
> I would go ahead and implement the patch right now.  It's a very easy
> patch to apply, and it produces a dramatic improvement in correctness.
Ok then, can you provide the RobustLineIntersector revision number
against I should run a diff ? I see only removal of code between
1.30 and 1.31 ...
--strk;
> Martin Davis, Senior Technical Architect
> Vivid Solutions Inc.      www.vividsolutions.com
> Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
> Phone: (250) 385 6040 - Local 308 Fax: (250) 385 6046
> > -----Original Message-----
> > From: strk at refractions.net [mailto:strk at refractions.net]
> > Sent: May 6, 2005 9:21 AM
> > To: Martin Davis
> > Cc: GEOS Development List
> > Subject: Re: [geos-devel] How robust is GEOS?
> > On Fri, May 06, 2005 at 08:43:51AM -0700, Martin Davis wrote:
> > > Kevin, List, strk:
> > > I've made an enhancement to JTS (based on a suggestion by
> > Kevin) which
> > > seems to solve the issue of computed intersection points
> > lying outside
> > > the intersection of the segment envelopes.  (This is simply one
> > > different function in RobustLineIntersector - it's an easy patch,
> > > strk).
> > > This still doesn't produce the ultimate desired result of computing
> > > intersections to the full 56 bits of double precision,
> > however.  We're
> > > working on a solution for that - will post it if and when it's done.
> > Ok. I'll wait for the final version before applying to GEOS.
> > Thanks. --strk;
> > > Martin
> > > 	From: geos-devel-bounces at geos.refractions.net
> > > [mailto:geos-devel-bounces at geos.refractions.net] On Behalf Of Kevin
> > > Wiebe
> > > 	Sent: May 3, 2005 7:00 AM
> > > 	To: geos-devel at geos.refractions.net
> > > 	Subject: [geos-devel] How robust is GEOS?
> > > 	I'm asking for advice here:  What is the most robust
> > (numerically
> > > stable) way to use GEOS?  What are its limitations?
> > > 	For our purposes we need to use code that is both as fast and
> > > accurate as possible.  As you probably know, when using a complex
> > > algorithm sometimes even small inaccuracies in geometric
> > computations
> > > can compound into drastically incorrect results.
> > > 	Here is a concrete example from real customer data:
> > > 	I have created two simple 2-point LINEs and used the
> > GEOS call to get
> > > the spot where they intersect:
> > > 	point = lineA.intersection(lineB);
> > > 	lineA = from (2089426.5233462777,1180182.3877339689) to
> > > (2085646.6891757075,1195618.7333999649)
> > > 	lineB = from (1889281.8148903656,1997547.0560044837) to
> > > (2259977.3672235999,483675.17050843034)
> > > 	the intersection point I get back is this:
> > > 	point = (2097408.2633752143,1144595.8008114607)
> > > 	This point is a significant distance away from any part
> > of lineA.  If
> > > one were to place this intersection point between the start and end
> > > points of lineA, the resulting line would look ridiculous.
> > > 	JTS returns the same result.
> > > 	Depending on your explanations for this I may have some
> > technical
> > > advice.
> > > 	Thanks for your comments,
> > > 	-Kevin-
> > > 	 Kevin Wiebe     Safe Software Inc.              kevin at safe.com
> > > 	      Senior     Surrey, BC, CANADA       phone: (604) 501-9985
> > > 	   Developer     http://www.safe.com        fax: (604) 501-9965
> geos-devel mailing list
> http://geos.refractions.net/mailman/listinfo/geos-devel
