[geos-devel] How robust is GEOS?
strk at refractions.net
Mon May 9 06:36:03 EDT 2005
I've ported the patches to GEOS. Thanks Martin, Kevin.
--strk;
On Fri, May 06, 2005 at 08:03:06PM +0200, strk at refractions.net wrote:
> On Fri, May 06, 2005 at 10:56:33AM -0700, Martin Davis wrote:
> > I would go ahead and implement the patch right now. It's a very easy
> > patch to apply, and it produces a dramatic improvement in correctness.
> Ok then, can you provide the RobustLineIntersector revision number
> against I should run a diff ? I see only removal of code between
> 1.30 and 1.31 ...
> --strk;
> > Martin Davis, Senior Technical Architect
> > Vivid Solutions Inc. www.vividsolutions.com
> > Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
> > Phone: (250) 385 6040 - Local 308 Fax: (250) 385 6046
> > > -----Original Message-----
> > > From: strk at refractions.net [mailto:strk at refractions.net]
> > > Sent: May 6, 2005 9:21 AM
> > > To: Martin Davis
> > > Cc: GEOS Development List
> > > Subject: Re: [geos-devel] How robust is GEOS?
> > > On Fri, May 06, 2005 at 08:43:51AM -0700, Martin Davis wrote:
> > > > Kevin, List, strk:
> > > > I've made an enhancement to JTS (based on a suggestion by
> > > Kevin) which
> > > > seems to solve the issue of computed intersection points
> > > lying outside
> > > > the intersection of the segment envelopes. (This is simply one
> > > > different function in RobustLineIntersector - it's an easy patch,
> > > > strk).
> > > > This still doesn't produce the ultimate desired result of computing
> > > > intersections to the full 56 bits of double precision,
> > > however. We're
> > > > working on a solution for that - will post it if and when it's done.
> > > Ok. I'll wait for the final version before applying to GEOS.
> > > Thanks. --strk;
> > > > Martin
> > > > From: geos-devel-bounces at geos.refractions.net
> > > > [mailto:geos-devel-bounces at geos.refractions.net] On Behalf Of Kevin
> > > > Wiebe
> > > > Sent: May 3, 2005 7:00 AM
> > > > To: geos-devel at geos.refractions.net
> > > > Subject: [geos-devel] How robust is GEOS?
> > > > I'm asking for advice here: What is the most robust
> > > (numerically
> > > > stable) way to use GEOS? What are its limitations?
> > > > For our purposes we need to use code that is both as fast and
> > > > accurate as possible. As you probably know, when using a complex
> > > > algorithm sometimes even small inaccuracies in geometric
> > > computations
> > > > can compound into drastically incorrect results.
> > > > Here is a concrete example from real customer data:
> > > > I have created two simple 2-point LINEs and used the
> > > GEOS call to get
> > > > the spot where they intersect:
> > > > point = lineA.intersection(lineB);
> > > > lineA = from (2089426.5233462777,1180182.3877339689) to
> > > > (2085646.6891757075,1195618.7333999649)
> > > > lineB = from (1889281.8148903656,1997547.0560044837) to
> > > > (2259977.3672235999,483675.17050843034)
> > > > the intersection point I get back is this:
> > > > point = (2097408.2633752143,1144595.8008114607)
> > > > This point is a significant distance away from any part
> > > of lineA. If
> > > > one were to place this intersection point between the start and end
> > > > points of lineA, the resulting line would look ridiculous.
> > > > JTS returns the same result.
> > > > Depending on your explanations for this I may have some
> > > technical
> > > > advice.
> > > > Thanks for your comments,
> > > > -Kevin-
> > > > Kevin Wiebe Safe Software Inc. kevin at safe.com
> > > > Senior Surrey, BC, CANADA phone: (604) 501-9985
> > > > Developer http://www.safe.com fax: (604) 501-9965
> > geos-devel mailing list
> > http://geos.refractions.net/mailman/listinfo/geos-devel
