[geos-devel] Buffering Multipolygons
Steve Lime
steve.lime at dnr.state.mn.us
Tue May 17 09:19:05 EDT 2005
What flavor of script or test data? Do you really want a perl/mapscript
script?
>>> strk at refractions.net 05/17/05 1:33 AM >>>
If you send a small script we can test it.
--strk;
On Tue, May 17, 2005 at 01:02:58AM -0500, Steve Lime wrote:
> Hi All: I'm wondering if someone can confirm that buffering a
> multipolygon works with GEOS 2.1.1. I'm testing my conversion code and
> am having problems with just this case: simple polgons with/without
> holes work fine, anything with multiple outer rings does not (bus
error
> on Mac OS). The conversion code must be close because computing a
convex
> hull on the same test shape works fine.
> I've attached a small graphic that shows the multipolygon (with GEOS
> computed convext hull)...
> Steve
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
