[geos-devel] Buffering Multipolygons
Chris Hodgson
chodgson at refractions.net
Tue May 17 12:36:06 EDT 2005
I think Martin Davis is off on holidays, so I will offer this tidbit - I
do recall that some JTS operations (union/intersection come to mind) do
NOT work on multi-polygons. I wouldn't be surprised if buffer was also
one of these operations.
The only convex hull algorithm I know works on a set of points, if a
similar one is used in JTS then it probably would work on any type of
shape, (even multi-*) because you would just break it down into the
constituent points.
My best bet is that you're code is right Steve - if you can buffer
regular polygons, and you can convex hull multi-polygons, then it seems
more likely to me that buffering multi's just doesn't work than it is
that there is some special case not being handled in your code :)
Chris
Steve Lime wrote:
> Hi All: I'm wondering if someone can confirm that buffering a
> multipolygon works with GEOS 2.1.1. I'm testing my conversion code and
> am having problems with just this case: simple polgons with/without
> holes work fine, anything with multiple outer rings does not (bus error
> on Mac OS). The conversion code must be close because computing a convex
> hull on the same test shape works fine.
> I've attached a small graphic that shows the multipolygon (with GEOS
> computed convext hull)...
> Steve
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
