[geos-devel] Buffering Multipolygons
Martin Davis mbdavis at VividSolutions.com
Tue May 17 13:46:37 EDT 2005
Nope, I'm still here... for a couple more days.
In JTS buffer works on *everything*, including MultiPolygons.  So this
might be a bug in GEOS.
Martin Davis, Senior Technical Architect
Vivid Solutions Inc.      www.vividsolutions.com
Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
Phone: (250) 385 6040 - Local 308 Fax: (250) 385 6046
> -----Original Message-----
> From: geos-devel-bounces at geos.refractions.net
> [mailto:geos-devel-bounces at geos.refractions.net] On Behalf Of
> Chris Hodgson
> Sent: May 17, 2005 9:36 AM
> To: GEOS Development List
> Subject: Re: [geos-devel] Buffering Multipolygons
> I think Martin Davis is off on holidays, so I will offer this
> tidbit - I
> do recall that some JTS operations (union/intersection come
> to mind) do
> NOT work on multi-polygons. I wouldn't be surprised if buffer
> was also
> one of these operations.
> The only convex hull algorithm I know works on a set of points, if a
> similar one is used in JTS then it probably would work on any type of
> shape, (even multi-*) because you would just break it down into the
> constituent points.
> My best bet is that you're code is right Steve - if you can buffer
> regular polygons, and you can convex hull multi-polygons,
> then it seems
> more likely to me that buffering multi's just doesn't work than it is
> that there is some special case not being handled in your code :)
> Chris
> Steve Lime wrote:
> > Hi All: I'm wondering if someone can confirm that buffering a
> > multipolygon works with GEOS 2.1.1. I'm testing my
> conversion code and
> > am having problems with just this case: simple polgons with/without
> > holes work fine, anything with multiple outer rings does not (bus
> > error on Mac OS). The conversion code must be close because
> computing
> > a convex hull on the same test shape works fine.
> > I've attached a small graphic that shows the multipolygon
> (with GEOS
> > computed convext hull)...
> > Steve
> > geos-devel mailing list
> > geos-devel at geos.refractions.net
> > http://geos.refractions.net/mailman/listinfo/geos-devel
