[geos-devel] Buffering Multipolygons
strk at refractions.net strk at refractions.net
Wed May 18 04:28:35 EDT 2005
On Tue, May 17, 2005 at 11:33:27PM -0500, Stephen Lime wrote:
> Sorry, not a regular  PostGIS user I'm afraid to say. Here's a simple
> WKT mutipolygon though:
>   MULTIPOLYGON(((10 10, 10 20, 20 20, 20 15, 10 10)), ((60 60, 70 7, 80
> 60, 60 60 )))
> Steve
=# select astext(buffer('MULTIPOLYGON(((10 10, 10 20, 20 20, 20 15, 10 10)), ((60 60, 70 7, 80 60, 60 60 )))', 0));
              astext
 POLYGON((60 60,80 60,70 7,60 60))
(1 row)
=# select postgis_geos_version();
 3.0.0
(1 row)
Is the result correct ?
3.0.0 is the CVS version (next release).
--strk;
> On May 17, 2005, at 2:47 PM, strk at refractions.net wrote:
> > On Tue, May 17, 2005 at 06:05:50PM +0200, strk at refractions.net
> > wrote:
> > > On Tue, May 17, 2005 at 08:19:06AM -0500, Steve Lime wrote:
> > > > What flavor of script or test data? Do you really want a
> > > > perl/mapscript
> > > > script?
> > > No, just an .sql script containing table creation, data load (WKT
> > > geoms)
> > > and the failing call to GeomUnion(). The dataset should be the
> > > smallest possible reproducing the problem.
> > Err.. sorry, the call is to buffer() not to GeomUnion,
> > so a single command should be able to show the problem and let us
> > test it on other versions.
> > Something like:
> >  select buffer('MULTIPOLYGON...', #);
> > --strk;
> > > --strk;
> > > > > > > strk at refractions.net 05/17/05 1:33 AM >>>
> > > > If you send a small script we can test it.
> > > > --strk;
> > > > On Tue, May 17, 2005 at 01:02:58AM -0500, Steve Lime wrote:
> > > > > Hi All: I'm wondering if someone can confirm that buffering a
> > > > > multipolygon works with GEOS 2.1.1. I'm testing my conversion
> > > > > code and
> > > > > am having problems with just this case: simple polgons
> > > > > with/without
> > > > > holes work fine, anything with multiple outer rings does not
> > > > > (bus
> > > > error
> > > > > on Mac OS). The conversion code must be close because
> > > > > computing a
> > > > convex
> > > > > hull on the same test shape works fine.
> > > > > I've attached a small graphic that shows the multipolygon
> > > > > (with GEOS
> > > > > computed convext hull)...
> > > > > Steve
> > > > > _______________________________________________
> > > > > geos-devel mailing list
> > > > > geos-devel at geos.refractions.net
> > > > > http://geos.refractions.net/mailman/listinfo/geos-devel
