[geos-devel] Buffering Multipolygons
Stephen Lime
sdlime at comcast.net
Wed May 18 00:33:27 EDT 2005
Sorry, not a regular PostGIS user I'm afraid to say. Here's a simple
WKT mutipolygon though:
MULTIPOLYGON(((10 10, 10 20, 20 20, 20 15, 10 10)), ((60 60, 70 7, 80
60, 60 60 )))
Steve
On May 17, 2005, at 2:47 PM, strk at refractions.net wrote:
> On Tue, May 17, 2005 at 06:05:50PM +0200, strk at refractions.net wrote:
>> On Tue, May 17, 2005 at 08:19:06AM -0500, Steve Lime wrote:
>>> What flavor of script or test data? Do you really want a
>>> perl/mapscript
>>> script?
>> No, just an .sql script containing table creation, data load (WKT
>> geoms)
>> and the failing call to GeomUnion(). The dataset should be the
>> smallest possible reproducing the problem.
> Err.. sorry, the call is to buffer() not to GeomUnion,
> so a single command should be able to show the problem and let us
> test it on other versions.
> Something like:
> select buffer('MULTIPOLYGON...', #);
> --strk;
>> --strk;
>>>>>> strk at refractions.net 05/17/05 1:33 AM >>>
>>> If you send a small script we can test it.
>>> --strk;
>>> On Tue, May 17, 2005 at 01:02:58AM -0500, Steve Lime wrote:
>>>> Hi All: I'm wondering if someone can confirm that buffering a
>>>> multipolygon works with GEOS 2.1.1. I'm testing my conversion code
>>>> and
>>>> am having problems with just this case: simple polgons with/without
>>>> holes work fine, anything with multiple outer rings does not (bus
>>> error
>>>> on Mac OS). The conversion code must be close because computing a
>>> convex
>>>> hull on the same test shape works fine.
>>>> I've attached a small graphic that shows the multipolygon (with GEOS
>>>> computed convext hull)...
>>>> Steve
>>>> _______________________________________________
>>>> geos-devel mailing list
>>>> geos-devel at geos.refractions.net
>>>> http://geos.refractions.net/mailman/listinfo/geos-devel
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20050517/941eb3a0/attachment.bin
