[geos-devel] 2.1 branch and 2.1.2
Paul Ramsey pramsey at refractions.net
Mon May 23 17:12:52 EDT 2005
Shall we roll out geos-2.1.2 and postgis 1.0.1?
P
On 23-May-05, at 12:28 PM, strk at refractions.net wrote:
> I've set up a branch for 2.1 code line (branch-2-1)
> Most ABI-compatible changes since 2.1.1 have already
> be applied to the branch.
> A new CHANGES file as been added, currently containing:
> Changes from 2.1.1 to 2.1.2
> - Segfault fix in Point::isEmpty
> - Mem Leak fix in OffsetCurveBuilder::getRingCurve
> - Bugfix in LineSegment::reverse
> - Added multipolygon buffering test in source/test/testLeaksBig
> - Ported JTS robustness patch for RobustLineIntersector
> - Removed useless Coordinate copies in OverlayOp::mergeZ()
> - Avoided throws by IsValid on invalid input
> - Stricter C++ syntax (math.h=>cmath, ieeefp.h in "C" block,
> ostringstream
>   instead of sprintf)
> - Better support for older compilers (Polygonizer::LineStringAdder
> friendship)
> - Removed useless Coordinate copies in CGAlgorithms::isOnLine()
> - Added support for polygonize and parametrized buffer tests in
> XMLTester
> - Fixed support for --includedir and --libdir
> - Fixed Z interpolation in LineIntersector
> --strk;
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
