[geos-devel] 2.1 branch and 2.1.2
strk at refractions.net
Tue May 24 03:14:02 EDT 2005
On Mon, May 23, 2005 at 02:12:52PM -0700, Paul Ramsey wrote:
> Shall we roll out geos-2.1.2 and postgis 1.0.1?
> P
For postgis 1.0.1 I think we're done (apart from srtext not
being updated and bugtracker being down).
For geos-2.1.2 I'd wait feedback from community for any bug
tests might be still around.
--strk;
> On 23-May-05, at 12:28 PM, strk at refractions.net wrote:
> >I've set up a branch for 2.1 code line (branch-2-1)
> >Most ABI-compatible changes since 2.1.1 have already
> >be applied to the branch.
> >A new CHANGES file as been added, currently containing:
> >Changes from 2.1.1 to 2.1.2
> >- Segfault fix in Point::isEmpty
> >- Mem Leak fix in OffsetCurveBuilder::getRingCurve
> >- Bugfix in LineSegment::reverse
> >- Added multipolygon buffering test in source/test/testLeaksBig
> >- Ported JTS robustness patch for RobustLineIntersector
> >- Removed useless Coordinate copies in OverlayOp::mergeZ()
> >- Avoided throws by IsValid on invalid input
> >- Stricter C++ syntax (math.h=>cmath, ieeefp.h in "C" block,
> >ostringstream
> > instead of sprintf)
> >- Better support for older compilers (Polygonizer::LineStringAdder
> >friendship)
> >- Removed useless Coordinate copies in CGAlgorithms::isOnLine()
> >- Added support for polygonize and parametrized buffer tests in
> >XMLTester
> >- Fixed support for --includedir and --libdir
> >- Fixed Z interpolation in LineIntersector
> >--strk;
> >_______________________________________________
> >geos-devel mailing list
> >geos-devel at geos.refractions.net
> >http://geos.refractions.net/mailman/listinfo/geos-devel
