[geos-devel] GEOS C API Suggestions
Mon Oct 17 11:13:40 EDT 2005
On 10/17/05, strk at refractions.net <strk at refractions.net> wrote:
> This mean __cplusplus is not defined by default with your compiler.
The __cplusplus is defined by my compiler.  I meant, *before* you
made these changes I needed to include geos_c.h like this:
extern "C" {
#include "geos_c.h"
> Do you think I can drop the construct from within geos_c.h then ?
No, I don't think you should drop it.
Best regards,
