[geos-devel] GEOS C API Suggestions
strk at refractions.net
Fri Oct 21 04:42:29 EDT 2005
On Sat, Oct 15, 2005 at 11:13:29PM -0400, Frank Warmerdam wrote:
> 5) I think it would be nice to provide entry points to directly
> create and destroy geometries however that is not really critical.
> However, I found it odd that calls like GEOS_GetNumCoordinate()
> and GEOSGetNumGeometries() were provided when no calls
> to get coordinates or geometries were provided.
I've been thinking about this. Geometry destruction is available
alread, so we're talking about fine-grained construction and
inspection.
In order to implement this the least we must do is provide
a CoordinateSequence abstract data type. To allow for internal
storage changes this might expose the following interfaces:
* Create a coordinate sequence specifying number and
* dimensions of coordinates
GEOSCoordSeq GEOSCoordSeq_create(uint size, uint dims);
/* Set ordinate values */
void GEOSCoordSeq_setX(uint idx, double value);
void GEOSCoordSeq_setY(uint idx, double value);
void GEOSCoordSeq_setZ(uint idx, double value);
void GEOSCoordSeq_setOrdinate(uint idx, uint dim, double value);
/* Get ordinate values */
double GEOSCoordSeq_getX(uint idx);
double GEOSCoordSeq_getY(uint idx);
double GEOSCoordSeq_getZ(uint idx);
double GEOSCoordSeq_getOrdinate(uint idx, uint dim);
/* Copy a coordinate sequence */
GEOSCoordSeq GEOSCoordSeq_clone(GEOSCoordSeq);
/* Destroy a coordinate sequence */
void GEOSCoordSeq_destroy(GEOSCoordSeq);
Then, we might construct specific geometry types.
GEOSGeom GEOSGeom_createPoint(GEOSCoordSeq cs);
GEOSGeom GEOSGeom_createLineString(GEOSCoordSeq cs);
GEOSGeom GEOSGeom_createLinearRing(GEOSCoordSeq cs);
And extract coordinates:
GEOSCoordSeq GEOSGeom_getCoordSeq(GEOSGeom g);
Finally, to complete constructors:
GEOSGeom GEOSGeom_createPolygon(GEOSGeom shell,
GEOSGeom *holes, uint nholes)
The following could replace GEOSMakeCollection, to be more consistent:
GEOSGeom GEOSGeom_createCollection(int type,
GEOSGeom *g, uint ngeoms);
About memory management the safer thing would be make extractors
return newly allocated objects and constructors copy input objects.
Comments ?
--strk;
