[geos-devel] CoordSeq ADT and fine-grained ctors for C-API (was:
GEOS C API Suggestions)
Frank Warmerdam
warmerdam at pobox.com
Fri Oct 21 12:01:30 EDT 2005
On 10/21/05, strk at refractions.net <strk at refractions.net> wrote:
> About performance and isolation, do we really want
> all the copies to happen ?
> Consider a multipolygon construction, you'll have copies:
> - of CoordSeq objects of the shell and each hole
> at each of the corresponding object construction/copy
> - of shell and hole geometry for each polygon
> construction/copy
> - of each polygon geometry at collection construction
> In practice it would take 3 copies of each involved CoordinateSequence.
> I'm thinking about making constructors take ownership of argument,
> and extractors (GetGeometryN, getExteriorRing, getCoordSeq..) return
> resources owned by the argument object...
> These changes would also allow changing any Ordinate value
> of any Geometry ...
> GEOSGeom g1 = GEOSGetGeometryN(g, 2);
> GEOSGeom hole3 = GEOSGetInteriorRingN(g1, 3);
> GEOSCoordSeq s = GEOSGetCoordSeq(hole3);
> GEOSCoordSeq_setX(s, 4);
> What do you think, is the advantage worth the danger ?
Strk,
If one of the rationales for the direct construction and query
support is to provide a "fastest" method of converting to and
from GEOS Geometries, then I think that avoiding copying
would be wise. I don't immediately intend to use the new
api entries so it doesn't matter so much to me, but if we convert
mapserver to use the GEOS C API then it speed would be an
issue.
I would say that the advantage is worth the danger, but the
rules about internal references and taking of ownership need
to be made clear in the docs.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
