[geos-devel] GEOS Buildbot
Howard Butler hobu at iastate.edu
Mon Apr 3 21:47:47 EDT 2006
All,
I have setup a Buildbot instance for GEOS HEAD at
http://geos.builds.hobu.net  There is a Linux FC4 box (with gcc
4.0.2), a Mac OSX box (with gcc 4.0.2 and configured to use GNU
libtool), and a Windows XP box (with MSVC 7.1).
The buildbot is also available on the #postgis IRC channel under the
handle "geosbuildbot".  It is setup to build nightly for all three
slaves, and you can manually invoke a build by going to the webpage,
clicking on a slave, and hitting the "build" button, or by giving the
bot in IRC a build command (geosbuildbot: commands).
Here's to an excellent, well-tested, and multi-platform GEOS 3.0 release!
Howard
