[geos-devel] GEOS Buildbot
strk at refractions.net strk at refractions.net
Tue Apr 4 06:00:34 EDT 2006
Thanks a lot Hobu!
It's being very useful.
--strk;
On Mon, Apr 03, 2006 at 07:47:47PM -0600, Howard Butler wrote:
> All,
> I have setup a Buildbot instance for GEOS HEAD at
> http://geos.builds.hobu.net  There is a Linux FC4 box (with gcc
> 4.0.2), a Mac OSX box (with gcc 4.0.2 and configured to use GNU
> libtool), and a Windows XP box (with MSVC 7.1).
> The buildbot is also available on the #postgis IRC channel under the
> handle "geosbuildbot".  It is setup to build nightly for all three
> slaves, and you can manually invoke a build by going to the webpage,
> clicking on a slave, and hitting the "build" button, or by giving the
> bot in IRC a build command (geosbuildbot: commands).
> Here's to an excellent, well-tested, and multi-platform GEOS 3.0 release!
> Howard
