[geos-devel] Geos 3 build issues on Windows
Howard Butler hobu at iastate.edu
Tue Apr 4 12:59:39 EDT 2006
OSX does this as well (uses gcc instead of g++).
At 11:55 AM 4/4/2006, Charlie Savage wrote:
>Well, that brings up another error - on MinGW the geos autoconf
>scripts use gcc not g++.  I posted a bug a message about that back
>in February I think it was.  I'll dig it up and put it in the bug database.
>Thus, I always manually edit the generated Make file and use
>g++.  That include libstdc++ by default - otherwise you can't even
>compile geos.
>Charlie
><mailto:strk at refractions.net>strk at refractions.net wrote:
>>On Sun, Apr 02, 2006 at 08:50:08PM -0600, Charlie Savage wrote:
>>>For MinGw - still doesn't build.  Same link error:
>>>c:\Development\MinGW\mingw32\bin\ld.exe: BFD 2.16.91 20060119 assertion
>>>fail ../../src/bfd/cofflink.c:1926
>>>make[2]: *** [libgeos.la] Error 5
>>>make[2]: Leaving directory `/usr/src/geos/source'
>>>make[1]: *** [all-recursive] Error 1
>>>make[1]: Leaving directory `/usr/src/geos/source'
>>>make: *** [all-recursive] Error 1
>>>Causes ld to have a segmentation fault.
>>Charlie, could you try adding -lstdc++ to
>>libgeos_la_LDFLAGS in source/Makefile.am ?
>>--strk;
>_______________________________________________
>geos-devel mailing list
>geos-devel at geos.refractions.net
>http://geos.refractions.net/mailman/listinfo/geos-devel
