[geos-devel] Geos 3 build issues on Windows
Charlie Savage
cfis at interserv.com
Tue Apr 4 13:07:01 EDT 2006
Interesting.
Here is the post where I originally brought up the issue and why its
happening:
http://geos.refractions.net/pipermail/geos-devel/2006-February/001707.html
And here is a bug report I just entered:
http://postgis.refractions.net/bugs/bug.php?op=show&bugid=85&pos=23
Charlie
Howard Butler wrote:
> OSX does this as well (uses gcc instead of g++).
> At 11:55 AM 4/4/2006, Charlie Savage wrote:
>> Well, that brings up another error - on MinGW the geos autoconf
>> scripts use gcc not g++. I posted a bug a message about that back in
>> February I think it was. I'll dig it up and put it in the bug database.
>> Thus, I always manually edit the generated Make file and use g++.
>> That include libstdc++ by default - otherwise you can't even compile
>> geos.
>> Charlie
>> <mailto:strk at refractions.net>strk at refractions.net wrote:
>>> On Sun, Apr 02, 2006 at 08:50:08PM -0600, Charlie Savage wrote:
>>>> For MinGw - still doesn't build. Same link error:
>>>> c:\Development\MinGW\mingw32\bin\ld.exe: BFD 2.16.91 20060119
>>>> assertion
>>>> fail ../../src/bfd/cofflink.c:1926
>>>> make[2]: *** [libgeos.la] Error 5
>>>> make[2]: Leaving directory `/usr/src/geos/source'
>>>> make[1]: *** [all-recursive] Error 1
>>>> make[1]: Leaving directory `/usr/src/geos/source'
>>>> make: *** [all-recursive] Error 1
>>>> Causes ld to have a segmentation fault.
>>> Charlie, could you try adding -lstdc++ to
>>> libgeos_la_LDFLAGS in source/Makefile.am ?
>>> --strk;
>> geos-devel mailing list
>> geos-devel at geos.refractions.net
>> http://geos.refractions.net/mailman/listinfo/geos-devel
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060404/10f677bd/smime.bin
