[geos-devel] Geos 3 build issues on Windows
Norman Vine nhv at cape.com
Tue Apr 4 13:25:46 EDT 2006
Charlie Savage writes:
> Here is the post where I originally brought up the issue and why its
> happening:
> http://geos.refractions.net/pipermail/geos-devel/2006-February/001707.html
Charlie
try
./configure --with-tag=CXX
then hand edit $GEOS / source / Makefile
about line 78
change
LINK = $(LIBTOOL) --tag=CC --mode=link $(CCLD) $(AM_CFLAGS) $(CFLAGS) \
to
LINK = $(LIBTOOL) --tag=CXX --mode=link $(CCLD) $(AM_CFLAGS) $(CFLAGS) \
and see if this helps
Norman
> Howard Butler wrote:
> > OSX does this as well (uses gcc instead of g++).
> > At 11:55 AM 4/4/2006, Charlie Savage wrote:
> >> Well, that brings up another error - on MinGW the geos autoconf
> >> scripts use gcc not g++.  I posted a bug a message about that back in
> >> February I think it was.  I'll dig it up and put it in the bug database.
> >> Thus, I always manually edit the generated Make file and use g++.
> >> That include libstdc++ by default - otherwise you can't even compile
> >> geos.
> >> Charlie
> >> <mailto:strk at refractions.net>strk at refractions.net wrote:
> >>> On Sun, Apr 02, 2006 at 08:50:08PM -0600, Charlie Savage wrote:
> >>>> For MinGw - still doesn't build.  Same link error:
> >>>> c:\Development\MinGW\mingw32\bin\ld.exe: BFD 2.16.91 20060119
> >>>> assertion
> >>>> fail ../../src/bfd/cofflink.c:1926
> >>>> make[2]: *** [libgeos.la] Error 5
> >>>> make[2]: Leaving directory `/usr/src/geos/source'
> >>>> make[1]: *** [all-recursive] Error 1
> >>>> make[1]: Leaving directory `/usr/src/geos/source'
> >>>> make: *** [all-recursive] Error 1
> >>>> Causes ld to have a segmentation fault.
> >>> Charlie, could you try adding -lstdc++ to
> >>> libgeos_la_LDFLAGS in source/Makefile.am ?
> >>> --strk;
> >> _______________________________________________
> >> geos-devel mailing list
> >> geos-devel at geos.refractions.net
> >> http://geos.refractions.net/mailman/listinfo/geos-devel
