[geos-devel] 2.2.2
Charlie Savage
cfis at interserv.com
Sun Apr 9 18:24:51 EDT 2006
Hi Strk,
A couple things from me:
1. The branch doesn't build on Linux. Its missing geos/ChangeLog,
which causes ./autogen.sh to only partially complete, which then causes
configure not to work. Fix is simple, add a ChangeLog (maybe its not
tagged with the branch?)
2. Could you apply the patch for the SRID bug:
http://postgis.refractions.net/bugs/bug.php?op=show&bugid=97
I.E. - this is the patch that changes WKBReader so that it sets the SRID
on newly created geometries as opposed to throwing away the SRID value.
I've extracted it out of the patches that I sent to you last week. This
patch does not make any changes to any GEOS apis so won't break ABI
compatibility. Note I've been using it for the last four months are so
and have unit tests in the Ruby test suite, so it should be well tested.
I will retest the SWIG build this evening on VC++, msys and linux and
report back any issues.
Thanks,
Charlie
strk at refractions.net wrote:
> Is there any pending issue before we release GEOS-2.2.2 ?
> Changes since 2.2.1 are:
> - Added GEOSArea(), GEOSLength(), GEOSEnvelope(), and GEOSGeomType() to the
> C API
> - Cleanups in C-API
> - Support for gcc-4
> - Fixed Polygon::equalsExact
> - Improved XMLTester
> - Fixed bug in NULL-factory Geometry constructor
> - Cleanups in SWIG wrappers
> - New Ruby bindings
> - Enumerated SweepLineEvent's DELETE and INSERT labels
> renamed to DELETE_EVENT and INSERT_EVENT.
> It will ship with C-API version 1.1.0
> --strk;
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060409/2ecf45f5/smime.bin
