[geos-devel] 2.2.2
strk at refractions.net strk at refractions.net
Mon Apr 10 04:55:01 EDT 2006
I back ported the SRID patch and added a 'cvs2cl' generated
ChangeLog in 2.2. branch.
--strk;
On Sun, Apr 09, 2006 at 04:24:51PM -0600, Charlie Savage wrote:
> Hi Strk,
> A couple things from me:
> 1.  The branch doesn't build on Linux.  Its missing geos/ChangeLog,
> which causes ./autogen.sh to only partially complete, which then causes
> configure not to work.  Fix is simple, add a ChangeLog (maybe its not
> tagged with the branch?)
> 2.  Could you apply the patch for the SRID bug:
> http://postgis.refractions.net/bugs/bug.php?op=show&bugid=97
> I.E. - this is the patch that changes WKBReader so that it sets the SRID
> on newly created geometries as opposed to throwing away the SRID value.
> I've extracted it out of the patches that I sent to you last week.  This
> patch does not make any changes to any GEOS apis so won't break ABI
> compatibility.  Note I've been using it for the last four months are so
> and have unit tests in the Ruby test suite, so it should be well tested.
> I will retest the SWIG build this evening on VC++, msys and linux and
> report back any issues.
> Thanks,
> Charlie
> strk at refractions.net wrote:
> >Is there any pending issue before we release GEOS-2.2.2 ?
> >Changes since 2.2.1 are:
> >- Added GEOSArea(), GEOSLength(), GEOSEnvelope(), and GEOSGeomType() to the
> >  C API
> >- Cleanups in C-API
> >- Support for gcc-4
> >- Fixed Polygon::equalsExact
> >- Improved XMLTester
> >- Fixed bug in NULL-factory Geometry constructor
> >- Cleanups in SWIG wrappers
> >- New Ruby bindings
> >- Enumerated SweepLineEvent's DELETE and INSERT labels
> >  renamed to DELETE_EVENT and INSERT_EVENT.
> >It will ship with C-API version 1.1.0
> >--strk;
> >_______________________________________________
> >geos-devel mailing list
> >geos-devel at geos.refractions.net
> >http://geos.refractions.net/mailman/listinfo/geos-devel
 /"\    ASCII Ribbon Campaign
 \ /    Respect for low technology.
  X     Keep e-mail messages readable by any computer system.
 / \    Keep it ASCII.
