[geos-devel] Perl bindings via SWIG
Ari Jolma ari.jolma at tkk.fi
Wed Aug 2 03:52:05 EDT 2006
On Tue, 01 Aug 2006 21:34:52 -0600 Charlie Savage <cfis at savagexi.com> wrote:
> Hi Ari,
> Great work.
> One thing to take a look at is the bindings in CVS for Geos 3
ok, yes that seems reasonable, but perhaps I wait until a tarball comes out :)
> Also, for GEOS 3 the SWIG bindings are included in the build system.
> For perl to be added would require the correct automake macros, see the
I wonder if Perl requires a bit different setup since it uses Makefile.PL
> > 3. ran swig (in msys) with arguments: -c++ -perl5 -o geos_wrap.cxx
> ../geos.i
> > The resulting geos_wrap.cxx had to be fixed by adding
> > #ifdef select
> >   #undef select
> > #endif
> > Around "Workaround perl5 global namespace..."
> Can you add this via %inline in perl.i?
This should be reported to the swig developers and fixed somewhere in
swig/Lib/perl5 I think. I already reported similar issues to them few months ago
but not yet this.
> Check out Geos 3, and let me know what annoying things you run into and
> I'll get the fixed.
I got into looking directly into GEOS because I'm writing a new Perl interface
to GDAL. Part of GEOS is part of GDAL's interface but there are some compromises
and/or things missing.
I've submitted an abstract for FOSS4G at Lausanne on my Perl work. Are you or
other Swig people going to attend?
Ari
> Once again, great work.
> Charlie
Prof. Ari Jolma
Kartografia ja Geoinformatiikka / Cartography and Geoinformatics
Teknillinen Korkeakoulu / Helsinki University of Technology
POBox 1200, 02015 TKK, Finland
Email: ari.jolma at tkk.fi URL: http://www.tkk.fi/~jolma
