[geos-devel] MinGW Support
Charlie Savage
cfis at savagexi.com
Thu Aug 3 14:11:40 EDT 2006
For GEOS 3 it would be really good to support mingw. I have not been
able to compile the geos 3 head branch using migw for a long time - I
get a series of linker errors that I posted to the last about a month
ago. Any help fixing them would be appreciated.
Anyway, just tried again after the move to SVN. And this time I can't
get past autogen didn't work.
$ ./autogen.sh
Running autoheader
' is already registered with AC_CONFIG_FILES.
autoconf/status.m4:848: AC_CONFIG_FILES is expanded from...
configure.in:297: the top level
autom4te: /bin/m4 failed with exit status: 1
autoheader: /usr/bin/autom4te failed with exit status: 1
Something went wrong, giving up!
Any ideas?
Cahrlie
Mateusz Loskot wrote:
> Paul Ramsey wrote:
>> What are the remaining tasks on getting 3.0 out the door? I'd like it
>> out sooner than later, it has the changes from the JTS 1.7 synch sitting
>> there, and people could get some use out of those if we'd just drop a
>> numbered release! We'll roll the next client's updates into a 3.0.1 or
>> 3.1.0.
> Certainly, I'm not able to answer your question, but I don't think (i've
> not heard from strk) that missing Unit Tests can defer 3.0 release.
> There is plenty of work to do to finish Unit Tests, but AFAIK it's
> highly recommended, not mandatory.
> There are 6 bugs on the bug tracker (4 of them seem to be important).
> So, I hope there are no reason to release GEOS 3.0.
> Best regards
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060803/8e7ef4f6/smime.bin
