[geos-devel] 3.0?
strk at refractions.net strk at refractions.net
Thu Aug 31 18:33:16 EDT 2006
On Mon, Aug 07, 2006 at 04:57:49PM -0500, Howard Butler wrote:
> All,
> GEOS trunk does not currently build on OSX because autogen is
> failing.  <http://geos.builds.hobu.net/>
Your OSX installation seems a bit confused. See:
http://geos.builds.hobu.net/macosx-darwin-tiger-10.4.5/builds/169/step-shell/0
http://geos.builds.hobu.net/macosx-darwin-tiger-10.4.5/builds/170/step-shell/0
In the former automake suggests to use AM_CONFIG_HEADER rather
then AC_CONFIG_HEADERS, the latter complains that AM_CONFIG_HEADER
is undefined ...
What automake version are you running ?
--strk;
