[geos-devel] Quadtree Help
Chris Hodgson chodgson at refractions.net
Thu Dec 7 12:24:21 EST 2006
I don't think Quadtree is intended to provide access to that many
records. I think you'd be much better off using postgis to store and
access >1M records.
Chris
Elavazhagan.M wrote:
> Hi All,
> When I try to insert millions of records to Geos::Qaudtree (Each record
> of 12 Bytes in size) the system is running out of memory. Is there any
> way to handle this issue?
> Thanks.
> Regards,
> Ela.
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
