[geos-devel] Building GDAL with GEOS in Unix
Elavazhagan.M
elavazhagan.mouniandy at kcubeconsulting.com
Thu Dec 14 08:58:55 EST 2006
Can anyone please guide me how to enable GEOS Support in GDAL (Unix)? I have
installed Geos 3.0.0rc2 in my system and configured GDAL 1.32 with the
following commands:
"./configure -with-geos=yes". This did not work so I tried with "./configure
--with-geos=/root/usr/bin/geos-config" also.
Although these commands worked well and I successfully installed GDAL, when
I run the command "ogr2ogr", it gives the following error message:
"ERROR 6: Geos support not enabled"
Do I need to change anything in the makefiles of GDAL?
Please help me to resolve this issue.
Thank you.
Regards,
Elavazhagan.M
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20061214/3a754651/attachment.html
