[geos-devel] GEOS Head no longer compiles on MinGW
Charlie Savage
cfis at interserv.com
Tue Feb 7 00:17:02 EST 2006
Hi everyone,
The recent changes to GEOS have broken the MinGW windows build (up to
two weeks ago everything built fine).
The first problem is that the generated makefiles have libtool use gcc
and not g++, thus the standard C++ library is not being linked. The
problem is that autoconf sees there are no sources a library it will
choose the C compiler, not the C++ compiler. This is now the case for
GEOS, if you look at makefile.am in the source directory.
libgeos_la_SOURCES =
Note there are no sources anymore. The post below describes the problem
- but provides no solution:
http://lists.debian.org/debian-mentors/2003/06/msg00000.html
This problem gets some hits on Google, but I've found no solutions.
Maybe someone knows how to fix this? For the moment I just manually
update the makefiles (which is the best solution offered in the post above).
The second issue is more critical. The MingW linker can't seem to
handle GEOS's new layout with a library in each directory. The linker
dies with a segmentation fault, and this error message:
mingw32\bin\ld.exe: BFD 2.16.91 20050827 assertion fail
../../src/bfd/cofflink.c:1926
Searching again with Google, its seems like lots of people have problems
with cofflink, but I can't seem to dig up any help on this issue. I
guess the next step is go find the source for cofflink and see what
assertion is failing.
Once again, any help appreciated!
Note my environment is MingW on Windows XP. g++ version 3.4.4, ld
version 2.16.91, libtool version 1.5.22, autoconf version 2.59.
Thanks,
Charlie
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060206/9a5807a3/smime.bin
