[geos-devel] SegmentString modeling
Mateusz Łoskot mateusz at loskot.net
Sat Feb 18 10:32:06 EST 2006
strk at refractions.net wrote:
>>>Need some help from C++ gurus. One of the new JTS classes expects to
>>>modify the Coordinates associated with a SegmentString.
>>I wonder why SegmentString::pts is declared as
>>const CoordinateSequence* pts;
>>As I see, in JTS sources SegmentString::pts is not declared as const.
>>I'm not a Java guru but IMHO const in Java has similar meaning
>>as in C++.
> I've been the 'const' pusher in GEOS. I tried adding
> const-correctness here and there to help maintainance
> and reduce unneeded copies.
I mostly agree but in this case const does not make better
const-correctness. Second, it causes problems as now while porting new
class which requires mutable access to SegmentString::pts which is
defined as const.
OK, I see one case when current solution makes const-correctness required:
void foo(const CoordinateSequence &a)
     // foo promises to not to modify 'a' object so
     // it requires SegmentString to hold 'a' as const pointer - as
     // it currently is defined
     // IMPORTANT!
     // if SegmentString holds 'a' by non-const pointer then foo
     // will fail because it cannot cast from const to non-const
     SegmentString b(&a);
This sentence market as IMPORTANT! is very important :-) in case you
decide to move SegmentString::pts from const to non-const declaration -
what I also suggested in my previous replies.
So, if there is some similar function defined as foo above then problems
may occur.
I hope my explanation is clear. If my english it very poor then please
let me know I'll try to make it clearer ;-)
Yesterday, I consulted the problem with my friend and he suggested to
move this case to more "modern C++" design solution based on policies.
Policy-based design of classes was introduced by Andrei Alexandrescu
http://en.wikipedia.org/wiki/Policy-based_design
and comes extremely handy in such cases, especially when you may expect
some design changes (just as this one about moving from const ->
non-const problem) in future.
Here is simple example how to handle const and non-const versions of the
same type using policies:
struct use_const
     typedef const A * pointer_type;
struct dont_use_const
     typedef A * pointer_type;
template <class ConstCorrectness>
class B
     typedef typename ConstCorrectness::pointer_type pointer_type;
     pointer_type a;
public:
     B(pointer_type p) : a(p) {}
     pointer_type get() { return a; }
Now, you can define const version:
B<use_const> b(&a);
and non-const version:
B<dont_use_const> b(&a);
Both versions are interchangable and follows the Liskov Substitution
Principle:
http://www.objectmentor.com/resources/articles/lsp.pdf
> I could take the const out of SegmentString but I guess
> JTS code itself is not enough to tell what the intended
> behaviour is.
That's usually the big problem when porting from Java or C# to C++ :-)
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
