[geos-devel] Segfault when passing malformed WKT to GEOSGeomFromWKT
strk at refractions.net strk at refractions.net
Sat Feb 18 15:17:55 EST 2006
On Sat, Feb 18, 2006 at 01:16:30PM -0700, Sean Gillies wrote:
> On Feb 18, 2006, at 12:37 PM, strk at refractions.net wrote:
> >On Sat, Feb 18, 2006 at 10:47:15AM -0700, Sean Gillies wrote:
> >>"POINT ()" sent to GEOSGeomFromWKT() results in a segfault with GEOS
> >>2.2.1. Is this a known issue? If so, what do you do in PostGIS to
> >>guard against this?
> >Doesn't seem a known issue, please file a bug report.
> >No worries for PostGIS, doesn't use WKT or WKB for GEOS<->PostGIS
> >Geometry conversion.
> >--strk;
> There's a GEOS issue tracker? I didn't see anything on http://
> geos.refractions.net.
Oh, it's the postgis bug tracker, can be used for GEOS as well
(there should be a GEOS project registered).
--strk;
