[geos-devel] Segfault when passing malformed WKT to
GEOSGeomFromWKT
Sean Gillies
sgillies at frii.com
Sat Feb 18 15:33:03 EST 2006
On Feb 18, 2006, at 1:17 PM, strk at refractions.net wrote:
> On Sat, Feb 18, 2006 at 01:16:30PM -0700, Sean Gillies wrote:
>> On Feb 18, 2006, at 12:37 PM, strk at refractions.net wrote:
>>> On Sat, Feb 18, 2006 at 10:47:15AM -0700, Sean Gillies wrote:
>>>> "POINT ()" sent to GEOSGeomFromWKT() results in a segfault with
>>>> GEOS
>>>> 2.2.1. Is this a known issue? If so, what do you do in PostGIS to
>>>> guard against this?
>>> Doesn't seem a known issue, please file a bug report.
>>> No worries for PostGIS, doesn't use WKT or WKB for GEOS<->PostGIS
>>> Geometry conversion.
>>> --strk;
>> There's a GEOS issue tracker? I didn't see anything on http://
>> geos.refractions.net.
> Oh, it's the postgis bug tracker, can be used for GEOS as well
> (there should be a GEOS project registered).
> --strk;
Thanks. One more question: how does GEOS represent the empty point
set? As NULL?
Sean
