[geos-devel] Building latest CVS HEAD with MSVC++ 8.0
Charlie Savage cfis at interserv.com
Wed Feb 22 15:36:46 EST 2006
Hi Mateusz,
Yes, I build geos with VC++ 8 fairly frequently.  I have a VC
solution/project I can send you if you'd like.  The one hang-up at the
moment is that VC++ does not have a round function in math.h, which is
used in HotPixel::scale for example.
Charlie
>> Hi,
>> Has anyone tried to build latest CVS HEAD with MSVC++ 8.0?
>> When I try to build it using makefile.vc I encounter following error:
>> CoordinateSequenceFactory.cpp
>> NMAKE : fatal error U1073: don't know how to make
>> 'geom\DefaultCoordinateSequence.obj'
>> Stop.
> I've seen in CVS log it was renamed near 1.19 rev.
> It seems makefile.vc has not been updated. Should I do it?
> Cheers
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060222/cde75751/smime.bin
