[geos-devel] Building latest CVS HEAD with MSVC++ 8.0
Charlie Savage
cfis at interserv.com
Wed Feb 22 17:40:19 EST 2006
One thing to follow up on. I realize there used to be VC++ solution in
the GEOS source tree. However, it wasn't maintained and thus was
removed a few months ago.
Is there any interest in having a working VC++ solution again? I don't
mind keeping it up to date since I do that locally anyways.
What I have now builds geos as a static library (have to because there
aren't any DLL_EXPORT/IMPORT declarations in the geos C++ code base),
builds the geos C dll, and builds the Ruby SWIG extension. It would be
easy enough to also add in building the Python SWIG extension.
Thanks,
Charlie
Mateusz Ĺoskot wrote:
> Charlie Savage wrote:
>> Take a look at an email from today on the MingW mailing list about
>> round (attached below).
> Yes, that confirms what I wrote.
> Although, is GEOS considered as conformable to C (C99) or C++ standard?
> AFAIK GEOS is a C++ port of the JTS.
>> Strk - can we get rid of the use of round in geos? If not, then I
>> think we have to have an implement in the GEOS source tree.
> I'd suggest to get rid of it too.
> Cheers
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060222/9e161610/smime.bin
