[geos-devel] Building latest CVS HEAD with MSVC++ 8.0
    Charlie Savage
    cfis at interserv.com
    Wed Feb 22 19:01:56 EST 2006
Hi Matuesz,
I was just offering to donate the Visual Studio C++ Solution files
(i.e., the VC++ project files) that I have to GEOS.
That is a separate thing from fixing the round function, which stops
VC++ from compiling GEOS whether you use Visual Studio, the Visual
Studio command line or nmake.
However, I gather the VC++ community doesn't use GEOS much though, since
there aren't any Visual Studio files or build scripts that GEOS provides
that work with VC++.
Charlie
Mateusz Łoskot wrote:
> Charlie Savage wrote:
>> One thing to follow up on.  I realize there used to be VC++ solution
>> in the GEOS source tree.  However, it wasn't maintained and thus was
>> removed a few months ago.
>> Is there any interest in having a working VC++ solution again?  I
>> don't mind keeping it up to date since I do that locally anyways.
> I don't understand. Are you talking about round function issue?
> Does it mean you are asking if it's worth to keep GEOS compilable
> with VC++ ?
> If I'm following your point, should I understand that GEOS is
> (usually) not compiled by the GEOS Community with VC++ at all?
> Cheers
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060222/b40dce2a/smime.bin
