[geos-devel] Building latest CVS HEAD with MSVC++ 8.0
Charlie Savage cfis at interserv.com
Wed Feb 22 19:41:32 EST 2006
Hi Chris,
Yup, understood.  I've been bugging strk a bunch about Windows.  VC++ is
quite close to working again (just the round issue).
Unfortunately, MingW broke (worked fine before) with the change to using
a bunch of static libraries that are linked at the end.  Everything
compiles fine, but a segmentation fault happens when linking.   See
http://sourceforge.net/mailarchive/message.php?msg_id=14729192 for more
info.  Unfortunately, I don't see any easy way to fix this and haven't
found a way to work around it.
Charlie
Chris Hodgson wrote:
> Mateusz Łoskot wrote:
> > I don't understand. Are you talking about round function issue?
> > Does it mean you are asking if it's worth to keep GEOS compilable
> > with VC++ ?
> > If I'm following your point, should I understand that GEOS is (usually)
> > not compiled by the GEOS Community with VC++ at all?
> The primary development target is linux/gcc-g++. However we certainly
> do want to maintain compatibiliy with solaris, windows/mingw, and
> native windows/VC++. As strk has mentioned, he's busy doing new work
> right now, and that will take priority over compatibility
> changes/improvements. Ideally we could get some people regularly
> testing on the various other platforms and submitting patches, etc. to
> keep everything compatible. Until we have these "platform champions",
> the other platforms will suffer :(
> Chris
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060222/60b79d81/smime.bin
