[geos-devel] [PATCH] Update to makefile.vc for building on Win32
with VC++
Mateusz Łoskot
mateusz at loskot.net
Fri Feb 24 07:27:32 EST 2006
Index: Makefile.vc
RCS file: /home/cvs/postgis/geos/source/Makefile.vc,v
retrieving revision 1.6
diff -u -a -r1.6 Makefile.vc
--- Makefile.vc 31 Jan 2006 21:42:01 -0000 1.6
+++ Makefile.vc 24 Feb 2006 11:49:19 -0000
@@ -34,17 +34,30 @@
# Revision 1.1 2004/12/03 16:25:47 frank
# New
+!INCLUDE dirlist.mak
+# Check compiler version given in command line
+# nmake -f makefile.vc MSVC_VER=xxxx
+!IF $(MSVC_VER) == 1400
+MSVC_CPPFLAGS = /EHs /D "_CRT_SECURE_NO_DEPRECATE"
+!ELSE
+MSVC_CPPFLAGS = /GX
+!ENDIF
+#CFLAGS = -Iheaders /GX /MD /GR /Zi /nologo
+#CFLAGS = -Iheaders /GX /MD /GR /O1 /D "NDEBUG" /nologo
+CFLAGS = -Iheaders /MD /GR /O2 /D "NDEBUG" /nologo \
+ $(MSVC_CPPFLAGS)
-CFLAGS = -Iheaders /GX /MD /GR /Zi /nologo
LIBNAME = geos.lib
DLLNAME = geos.dll
SLIBNAME = geos_i.lib
-OBJ = algorithm\CGAlgorithms.obj \
- algorithm\CentroidArea.obj \
+OBJ = algorithm\CentroidArea.obj \
algorithm\CentroidLine.obj \
algorithm\CentroidPoint.obj \
+ algorithm\CGAlgorithms.obj \
algorithm\ConvexHull.obj \
algorithm\HCoordinate.obj \
algorithm\InteriorPointArea.obj \
@@ -56,14 +69,14 @@
algorithm\NotRepresentableException.obj \
algorithm\PointLocator.obj \
algorithm\RobustDeterminant.obj \
- algorithm\SIRtreePointInRing.obj \
algorithm\SimplePointInAreaLocator.obj \
algorithm\SimplePointInRing.obj \
+ algorithm\SIRtreePointInRing.obj \
geom\Coordinate.obj \
+ geom\CoordinateArraySequence.obj \
+ geom\CoordinateArraySequenceFactory.obj \
geom\CoordinateSequence.obj \
geom\CoordinateSequenceFactory.obj \
- geom\DefaultCoordinateSequence.obj \
- geom\DefaultCoordinateSequenceFactory.obj \
geom\Dimension.obj \
geom\Envelope.obj \
geom\Geometry.obj \
@@ -72,9 +85,9 @@
geom\GeometryComponentFilter.obj \
geom\GeometryFactory.obj \
geom\IntersectionMatrix.obj \
+ geom\LinearRing.obj \
geom\LineSegment.obj \
geom\LineString.obj \
- geom\LinearRing.obj \
geom\Location.obj \
geom\MultiLineString.obj \
geom\MultiPoint.obj \
@@ -88,15 +101,7 @@
geom\util\LinearComponentExtracter.obj \
geom\util\PointExtracter.obj \
geom\util\PolygonExtracter.obj \
- geomgraph\index\MonotoneChain.obj \
- geomgraph\index\MonotoneChainEdge.obj \
- geomgraph\index\MonotoneChainIndexer.obj \
- geomgraph\index\SegmentIntersector.obj \
- geomgraph\index\SimpleEdgeSetIntersector.obj \
- geomgraph\index\SimpleMCSweepLineIntersector.obj \
- geomgraph\index\SimpleSweepLineIntersector.obj \
- geomgraph\index\SweepLineEvent.obj \
- geomgraph\index\SweepLineSegment.obj \
+ geom\util\ShortCircuitedGeometryVisitor.obj \
geomgraph\Depth.obj \
geomgraph\DirectedEdge.obj \
geomgraph\DirectedEdgeStar.obj \
@@ -110,6 +115,14 @@
geomgraph\EdgeRing.obj \
geomgraph\GeometryGraph.obj \
geomgraph\GraphComponent.obj \
+ geomgraph\index\MonotoneChainEdge.obj \
+ geomgraph\index\MonotoneChainIndexer.obj \
+ geomgraph\index\SegmentIntersector.obj \
+ geomgraph\index\SimpleEdgeSetIntersector.obj \
+ geomgraph\index\SimpleMCSweepLineIntersector.obj \
+ geomgraph\index\SimpleSweepLineIntersector.obj \
+ geomgraph\index\SweepLineEvent.obj \
+ geomgraph\index\SweepLineSegment.obj \
geomgraph\Label.obj \
geomgraph\Node.obj \
geomgraph\NodeFactory.obj \
@@ -118,32 +131,32 @@
geomgraph\Position.obj \
geomgraph\Quadrant.obj \
geomgraph\TopologyLocation.obj \
+ index\bintree\Bintree.obj \
index\bintree\BinTreeInterval.obj \
index\bintree\BinTreeNode.obj \
- index\bintree\Bintree.obj \
index\bintree\Key.obj \
index\bintree\NodeBase.obj \
index\bintree\Root.obj \
+ index\chain\indexMonotoneChain.obj \
index\chain\MonotoneChainBuilder.obj \
index\chain\MonotoneChainOverlapAction.obj \
index\chain\MonotoneChainSelectAction.obj \
- index\chain\indexMonotoneChain.obj \
index\quadtree\DoubleBits.obj \
index\quadtree\IntervalSize.obj \
+ index\quadtree\Quadtree.obj \
index\quadtree\QuadTreeKey.obj \
index\quadtree\QuadTreeNode.obj \
index\quadtree\QuadTreeNodeBase.obj \
index\quadtree\QuadTreeRoot.obj \
- index\quadtree\Quadtree.obj \
index\strtree\AbstractNode.obj \
index\strtree\AbstractSTRtree.obj \
index\strtree\Interval.obj \
index\strtree\ItemBoundable.obj \
index\strtree\SIRtree.obj \
index\strtree\STRtree.obj \
+ index\sweepline\indexSweepLineEvent.obj \
index\sweepline\SweepLineIndex.obj \
index\sweepline\SweepLineInterval.obj \
- index\sweepline\indexSweepLineEvent.obj \
io\ByteOrderValues.obj \
io\ParseException.obj \
io\StringTokenizer.obj \
@@ -153,25 +166,25 @@
io\WKTReader.obj \
io\WKTWriter.obj \
io\Writer.obj \
- io\markup\MarkupSTL.obj \
- noding\snapround\SegmentSnapper.obj \
- noding\snapround\SimpleSegmentStringsSnapper.obj \
- noding\snapround\SnapRounder.obj \
+ noding\IntersectionAdder.obj \
+ noding\IntersectionFinderAdder.obj \
noding\IteratedNoder.obj \
- noding\MCQuadtreeNoder.obj \
- noding\Noder.obj \
+ noding\MCIndexNoder.obj \
noding\NodingValidator.obj \
+ noding\Octant.obj \
+ noding\ScaledNoder.obj \
noding\SegmentNode.obj \
noding\SegmentNodeList.obj \
noding\SegmentString.obj \
noding\SimpleNoder.obj \
- noding\nodingSegmentIntersector.obj \
- operation\GeometryGraphOperation.obj \
- operation\IsSimpleOp.obj \
- operation\buffer\DepthSegment.obj \
+ noding\snapround\HotPixel.obj \
+ noding\snapround\MCIndexPointSnapper.obj \
+ noding\snapround\MCIndexSnapRounder.obj \
+ noding\snapround\SimpleSnapRounder.obj \
operation\buffer\BufferBuilder.obj \
operation\buffer\BufferOp.obj \
operation\buffer\BufferSubgraph.obj \
+ operation\buffer\DepthSegment.obj \
operation\buffer\OffsetCurveBuilder.obj \
operation\buffer\OffsetCurveSetBuilder.obj \
operation\buffer\RightmostEdgeFinder.obj \
@@ -180,11 +193,14 @@
operation\distance\ConnectedElementPointFilter.obj \
operation\distance\DistanceOp.obj \
operation\distance\GeometryLocation.obj \
+ operation\GeometryGraphOperation.obj \
+ operation\IsSimpleOp.obj \
operation\linemerge\EdgeString.obj \
operation\linemerge\LineMergeDirectedEdge.obj \
operation\linemerge\LineMergeEdge.obj \
operation\linemerge\LineMergeGraph.obj \
operation\linemerge\LineMerger.obj \
+ operation\linemerge\LineSequencer.obj \
operation\overlay\EdgeSetNoder.obj \
operation\overlay\ElevationMatrix.obj \
operation\overlay\ElevationMatrixCell.obj \
@@ -198,9 +214,12 @@
operation\overlay\PolygonBuilder.obj \
operation\polygonize\PolygonizeDirectedEdge.obj \
operation\polygonize\PolygonizeEdge.obj \
+ operation\polygonize\polygonizeEdgeRing.obj \
operation\polygonize\PolygonizeGraph.obj \
operation\polygonize\Polygonizer.obj \
- operation\polygonize\polygonizeEdgeRing.obj \
+ operation\predicate\RectangleContains.obj \
+ operation\predicate\RectangleIntersects.obj \
+ operation\predicate\SegmentIntersectionTester.obj \
operation\relate\EdgeEndBuilder.obj \
operation\relate\EdgeEndBundle.obj \
operation\relate\EdgeEndBundleStar.obj \
@@ -217,6 +236,7 @@
operation\valid\SimpleNestedRingTester.obj \
operation\valid\SweeplineNestedRingTester.obj \
operation\valid\TopologyValidationError.obj \
+ planargraph\algorithm\ConnectedSubgraphFinder.obj \
planargraph\planarDirectedEdge.obj \
planargraph\planarDirectedEdgeStar.obj \
planargraph\planarEdge.obj \
@@ -224,6 +244,7 @@
planargraph\planarNode.obj \
planargraph\planarNodeMap.obj \
planargraph\planarPlanarGraph.obj \
+ planargraph\planarSubgraph.obj \
precision\CommonBits.obj \
precision\CommonBitsOp.obj \
precision\CommonBitsRemover.obj \
@@ -232,17 +253,17 @@
util\Assert.obj \
util\AssertionFailedException.obj \
util\CoordinateArrayFiter.obj \
- util\GEOSException.obj \
util\GeometricShapeFactory.obj \
+ util\GEOSException.obj \
util\IllegalArgumentException.obj \
util\Profiler.obj \
util\UniqueCoordinateArrayFilter.obj \
util\UnsupportedOperationException.obj \
- capi\geos_c.obj
+ ..\capi\geos_c.obj
TEST_EXE = TestSweepLineSpeed.exe
-default: $(LIBNAME) $(DLLNAME) $(TEST_EXE)
+default: $(LIBNAME) $(DLLNAME)
$(LIBNAME): headers/geos/platform.h $(OBJ)
if exist $(LIBNAME) del $(LIBNAME)
@@ -261,13 +282,17 @@
$(CC) $(CFLAGS) /c $*.c /Fo$@
clean:
- del $(OBJ)
del $(LIBNAME)
del $(SLIBNAME)
del $(DLLNAME)
- del bigtest\*.obj
- del capi\*.obj
+ del ..\capi\*.obj
del *.exe
+ del *.exp
+ del *.ilk
+ del *.pdb
+ for %d in ( $(GEOS_DIRLIST) ) do \
+ del %d\*.obj
TestSweepLineSpeed.exe: $(LIBNAME) \
bigtest\GeometryTestFactory.obj \
Mateusz Łoskot
http://mateusz.loskot.net
