[geos-devel] geos-2.2.0 / FreeBSD 4
Benjamin Thelen bt at ccgis.de
Tue Jan 10 10:37:19 EST 2006
Hello,
I used the FreeBSD ports' geos and bend the geos port to use gcc34 what
lead to the error I've send to you yesterday. I did a make clean, but
the means I used to force the FreeBSD geos port to use gcc34 did
obviously not suffice.
Doing a "gmake clean && ./configure CC=gcc34 CXX=g++34 && gmake" not
using the ports version did it:
root at wms1# chmod u+x tools/geos-config
root at wms1# tools/geos-config --version
2.2.1
This is geos-2.2.1 built with gcc34 on FreeBSD 4.11. Of course up to
now, I don't know, whether geos will work correctly! Are there maybe
some tests I can perform to check the functionality quickly?
I'll get in touch with the ports maintainer again, I think.
Thanks,
Ben
strk at refractions.net schrieb:
> On Mon, Jan 09, 2006 at 02:27:28PM +0100, Benjamin Thelen wrote:
>>Well, I don't have 2.96, but I have 3.4.6, what doesn't do a better job,
>>I'm afraid:
> Is this after a make clean ?
> --strk;
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
