[geos-devel] geos-2.2.0 / FreeBSD 4
strk at refractions.net strk at refractions.net
Tue Jan 10 11:46:29 EST 2006
You can:
(1)
	$ cd source/test
	$ ./XMLTester testLeaksBig.xml | tail -4
(2)
	- Build postgis against the newly installed GEOS
	$ make test
--strk;
On Tue, Jan 10, 2006 at 04:37:19PM +0100, Benjamin Thelen wrote:
> Hello,
> I used the FreeBSD ports' geos and bend the geos port to use gcc34 what
> lead to the error I've send to you yesterday. I did a make clean, but
> the means I used to force the FreeBSD geos port to use gcc34 did
> obviously not suffice.
> Doing a "gmake clean && ./configure CC=gcc34 CXX=g++34 && gmake" not
> using the ports version did it:
> root at wms1# chmod u+x tools/geos-config
> root at wms1# tools/geos-config --version
> 2.2.1
> This is geos-2.2.1 built with gcc34 on FreeBSD 4.11. Of course up to
> now, I don't know, whether geos will work correctly! Are there maybe
> some tests I can perform to check the functionality quickly?
> I'll get in touch with the ports maintainer again, I think.
> Thanks,
> Ben
> strk at refractions.net schrieb:
> >On Mon, Jan 09, 2006 at 02:27:28PM +0100, Benjamin Thelen wrote:
> >>Well, I don't have 2.96, but I have 3.4.6, what doesn't do a better job,
> >>I'm afraid:
> >Is this after a make clean ?
> >--strk;
> >_______________________________________________
> >geos-devel mailing list
> >geos-devel at geos.refractions.net
> >http://geos.refractions.net/mailman/listinfo/geos-devel
 /"\    ASCII Ribbon Campaign
 \ /    Respect for low technology.
  X     Keep e-mail messages readable by any computer system.
 / \    Keep it ASCII.
