[geos-devel] geos-2.2.0 / FreeBSD 4
Benjamin Thelen bt at ccgis.de
Thu Jan 12 04:59:42 EST 2006
Thank you! Meanwhile Konstatin has solved the error. It had something to
with a wrong version of libtool.
Ben
strk at refractions.net schrieb:
> You can:
> (1)
> 	$ cd source/test
> 	$ ./XMLTester testLeaksBig.xml | tail -4
> (2)
> 	- Build postgis against the newly installed GEOS
> 	$ make test
> --strk;
> On Tue, Jan 10, 2006 at 04:37:19PM +0100, Benjamin Thelen wrote:
>>Hello,
>>I used the FreeBSD ports' geos and bend the geos port to use gcc34 what
>>lead to the error I've send to you yesterday. I did a make clean, but
>>the means I used to force the FreeBSD geos port to use gcc34 did
>>obviously not suffice.
>>Doing a "gmake clean && ./configure CC=gcc34 CXX=g++34 && gmake" not
>>using the ports version did it:
>>root at wms1# chmod u+x tools/geos-config
>>root at wms1# tools/geos-config --version
>>2.2.1
>>This is geos-2.2.1 built with gcc34 on FreeBSD 4.11. Of course up to
>>now, I don't know, whether geos will work correctly! Are there maybe
>>some tests I can perform to check the functionality quickly?
>>I'll get in touch with the ports maintainer again, I think.
>>Thanks,
>>Ben
>>>On Mon, Jan 09, 2006 at 02:27:28PM +0100, Benjamin Thelen wrote:
>>>>Well, I don't have 2.96, but I have 3.4.6, what doesn't do a better job,
>>>>I'm afraid:
>>>Is this after a make clean ?
>>>--strk;
>>>_______________________________________________
>>>geos-devel mailing list
>>>geos-devel at geos.refractions.net
>>>http://geos.refractions.net/mailman/listinfo/geos-devel
