[geos-devel] GEOS-3.0.0rc1 in a week, SWIG status ?
Michael Fuhr mike at fuhr.org
Wed Jul 5 23:40:38 EDT 2006
On Thu, Jul 06, 2006 at 01:35:59AM +0200, strk wrote:
> Charlie, we'll release the first candidate of GEOS in a week.
I just tried building GEOS CVS on Solaris 9 and got several undefined
symbol errors while linking capi/geostest.  I haven't built GEOS
CVS on Solaris for a long time so I don't know when this problem
started, but I have a libgeos-3.0.0.so from 16 Jan that appears to
work.
Here's what the linker complained about:
geos::index::bintree::NodeBase::addAllItems(std::vector<void*, std::allocator<void*> >*)
geos::index::bintree::NodeBase::addAllItemsFromOverlapping(geos::index::bintree::Interval*, std::vector<void*, std::allocator<void*> >*)
typeinfo for geos::index::bintree::NodeBase
geos::index::bintree::Interval::getMin()
geos::index::bintree::Interval::getMax()
geos::index::bintree::NodeBase::NodeBase()
geos::index::bintree::NodeBase::~NodeBase()
geos::index::bintree::Interval::getWidth()
geos::index::bintree::NodeBase::nodeSize()
geos::index::bintree::Interval::Interval(geos::index::bintree::Interval*)
geos::index::bintree::Interval::Interval()
geos::index::bintree::Interval::~Interval()
geos::index::bintree::Interval::Interval(double, double)
geos::index::bintree::NodeBase::add(void*)
geos::index::bintree::Root::insert(geos::index::bintree::Interval*, void*)
geos::index::bintree::NodeBase::size()
geos::index::bintree::NodeBase::depth()
geos::index::bintree::NodeBase::getItems()
Earlier I see the following warnings and errors:
rm -fr .libs/libgeos.lax/libindex.a
mkdir .libs/libgeos.lax/libindex.a
(cd .libs/libgeos.lax/libindex.a && ar x /<path omitted>/source/index/.libs/libindex.a)
libtool: link: warning: object name conflicts; renaming object files
libtool: link: warning: to ensure that they will not overwrite
Mutually exclusive options were given!
Usage:  uniq [-c|-d|-u][-f fields][-s char] [input_file [output_file]]
Or:     uniq [-c|-d|-u][-n][+m] [input_file [output_file]]
../libtool: -r: is not an identifier
I see these messages only for libindex; other libraries build without
complaint.  uniq appears to be failing because of the options it's
passed.
I don't know much about libtool but it looks involved.  Any ideas?
Michael Fuhr
