[geos-devel] GEOS-3.0.0rc1 in a week, SWIG status ?
strk at refractions.net
Thu Jul 6 03:12:25 EDT 2006
It seems a problem with the libtool script for your platform.
Maybe using another version ? libtoolize -f ?
The problem is probably there since we renamed classes to have
same classnames in different namespaces (to reflect JTS layout).
--strk;
On Wed, Jul 05, 2006 at 09:40:38PM -0600, Michael Fuhr wrote:
> On Thu, Jul 06, 2006 at 01:35:59AM +0200, strk wrote:
> > Charlie, we'll release the first candidate of GEOS in a week.
> I just tried building GEOS CVS on Solaris 9 and got several undefined
> symbol errors while linking capi/geostest. I haven't built GEOS
> CVS on Solaris for a long time so I don't know when this problem
> started, but I have a libgeos-3.0.0.so from 16 Jan that appears to
> work.
> Here's what the linker complained about:
> geos::index::bintree::NodeBase::addAllItems(std::vector<void*, std::allocator<void*> >*)
> geos::index::bintree::NodeBase::addAllItemsFromOverlapping(geos::index::bintree::Interval*, std::vector<void*, std::allocator<void*> >*)
> typeinfo for geos::index::bintree::NodeBase
> geos::index::bintree::Interval::getMin()
> geos::index::bintree::Interval::getMax()
> geos::index::bintree::NodeBase::NodeBase()
> geos::index::bintree::NodeBase::~NodeBase()
> geos::index::bintree::Interval::getWidth()
> geos::index::bintree::NodeBase::nodeSize()
> geos::index::bintree::Interval::Interval(geos::index::bintree::Interval*)
> geos::index::bintree::Interval::Interval()
> geos::index::bintree::Interval::~Interval()
> geos::index::bintree::Interval::Interval(double, double)
> geos::index::bintree::NodeBase::add(void*)
> geos::index::bintree::Root::insert(geos::index::bintree::Interval*, void*)
> geos::index::bintree::NodeBase::size()
> geos::index::bintree::NodeBase::depth()
> geos::index::bintree::NodeBase::getItems()
> Earlier I see the following warnings and errors:
> rm -fr .libs/libgeos.lax/libindex.a
> mkdir .libs/libgeos.lax/libindex.a
> (cd .libs/libgeos.lax/libindex.a && ar x /<path omitted>/source/index/.libs/libindex.a)
> libtool: link: warning: object name conflicts; renaming object files
> libtool: link: warning: to ensure that they will not overwrite
> Mutually exclusive options were given!
> Usage: uniq [-c|-d|-u][-f fields][-s char] [input_file [output_file]]
> Or: uniq [-c|-d|-u][-n][+m] [input_file [output_file]]
> ../libtool: -r: is not an identifier
> I see these messages only for libindex; other libraries build without
> complaint. uniq appears to be failing because of the options it's
> passed.
> I don't know much about libtool but it looks involved. Any ideas?
> Michael Fuhr
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
/"\ ASCII Ribbon Campaign
\ / Respect for low technology.
X Keep e-mail messages readable by any computer system.
/ \ Keep it ASCII.
