[geos-devel] GEOS-3.0.0rc1 in a week, SWIG status ?
Michael Fuhr mike at fuhr.org
Thu Jul 6 09:55:46 EDT 2006
On Thu, Jul 06, 2006 at 09:12:25AM +0200, strk at refractions.net wrote:
> It seems a problem with the libtool script for your platform.
> Maybe using another version ? libtoolize -f ?
I installed a different libtool and the GEOS build succeeded.  For
the archives, I had been using libtool-1.5-sol9-sparc-local from
sunfreeware.com; I replaced it with libtool-1.5.22 built from source.
That appears to have worked, at least well enough to build all of
GEOS.
I'm still having a few problems on Solaris 9/sparc, though.  During
the build I see a lot of the following warnings:
warning: #warning "Could not find 64bit integer definition!"
warning: right shift count >= width of type
I'm also getting some test failures; see the attached file.
Michael Fuhr
---> group: geos::io::ByteOrderValues, test: test<2>
     problem: assertion failed
     failed assertion: "putDouble big endian[4]"
---> group: geos::io::ByteOrderValues, test: test<3>
     failed assertion: "putLong big endian[3]"
---> group: geos::io::WKBReader, test: test<2>
     failed assertion: "NDR output: expected 010200000002000000000000000000F03F000000000000004000000000000008400000000000001040 actual 0102000000020000000000F03F0000F03F000000400000004000000840000008400000104000001040"
---> group: geos::io::WKBReader, test: test<3>
     failed assertion: "NDR output: expected 0103000000020000000500000000000000000000000000000000000000000000000000244000000000000000000000000000002440000000000000244000000000000000000000000000002440000000000000000000000000000000000400000000000000000000400000000000000040000000000000004000000000000018400000000000001840000000000000104000000000000000400000000000000040 actual 0103000000020000000500000000000000000000000000000000000000000024400000244000000000000000000000244000002440000024400000244000000000000000000000244000002440000000000000000000000000000000000400000000000040000000400000004000000040000000400000004000001840000018400000184000001840000010400000104000000040000000400000004000000040"
---> group: geos::io::WKBReader, test: test<4>
     failed assertion: "NDR output: expected 010400000005000000010100000000000000000000000000000000000000010100000000000000000024400000000000000000010100000000000000000024400000000000002440010100000000000000000000000000000000002440010100000000000000000000000000000000000000 actual 010400000005000000010100000000000000000000000000000000000000010100000000002440000024400000000000000000010100000000002440000024400000244000002440010100000000000000000000000000244000002440010100000000000000000000000000000000000000"
---> group: geos::io::WKBReader, test: test<5>
     failed assertion: "NDR output: expected 010500000002000000010200000005000000000000000000000000000000000000000000000000002440000000000000000000000000000024400000000000002440000000000000000000000000000024400000000000002440000000000000344001020000000400000000000000000000400000000000000040000000000000004000000000000018400000000000001840000000000000104000000000000034400000000000000040 actual 010500000002000000010200000005000000000000000000000000000000000000000000244000002440000000000000000000002440000024400000244000002440000000000000000000002440000024400000244000002440000034400000344001020000000400000000000040000000400000004000000040000000400000004000001840000018400000184000001840000010400000104000003440000034400000004000000040"
---> group: geos::io::WKBReader, test: test<6>
     failed assertion: "NDR output: expected 0106000000020000000103000000020000000500000000000000000000000000000000000000000000000000244000000000000000000000000000002440000000000000244000000000000000000000000000002440000000000000000000000000000000000400000000000000000000400000000000000040000000000000004000000000000018400000000000001840000000000000104000000000000000400000000000000040010300000001000000040000000000000000004E400000000000004E400000000000004E400000000000004940000000000080514000000000000044400000000000004E400000000000004E40 actual 01060000000200000001030000000200000005000000000000000000000000000000000000000000244000002440000000000000000000002440000024400000244000002440000000000000000000002440000024400000000000000000000000000000000004000000000000400000004000000040000000400000004000000040000018400000184000001840000018400000104000001040000000400000004000000040000000400103000000010000000400000000004E4000004E4000004E4000004E4000004E4000004E4000004940000049400080514000805140000044400000444000004E4000004E4000004E4000004E40"
---> group: geos::io::WKBReader, test: test<7>
     failed assertion: "NDR output: expected 010700000006000000010100000000000000000000000000000000000000010200000002000000000000000000F03F00000000000000400000000000000840000000000000104001030000000200000005000000000000000000000000000000000000000000000000002440000000000000000000000000000024400000000000002440000000000000000000000000000024400000000000000000000000000000000004000000000000000000004000000000000000400000000000000040000000000000184000000000000018400000000000001040000000000000004000000000000000400104000000050000000101000000000000000000000000000000000000000101000000000000000000244000000000000000000101000000000000000000244000000000000024400101000000000000000000000000000000000024400101000000000000000000000000000000000000000105000000020000000102000000050000000000000000000000000000000000000000000000000024400000000000000000000000000000244000000000000024400000000000000000000000000000244000000000000024400000000000003440010200000004000000000000000000004000000000000000400000000000000040000000000000184000000000000018400000000000001040000000000000344000000000000000400106000000020000000103000000020000000500000000000000000000000000000000000000000000000000244000000000000000000000000000002440000000000000244000000000000000000000000000002440000000000000000000000000000000000400000000000000000000400000000000000040000000000000004000000000000018400000000000001840000000000000104000000000000000400000000000000040010300000001000000040000000000000000004E400000000000004E400000000000004E400000000000004940000000000080514000000000000044400000000000004E400000000000004E40 actual 0107000000060000000101000000000000000000000000000000000000000102000000020000000000F03F0000F03F000000400000004000000840000008400000104000001040010300000002000000050000000000000000000000000000000000000000002440000024400000000000000000000024400000244000002440000024400000000000000000000024400000244000000000000000000000000000000000040000000000004000000040000000400000004000000040000000400000184000001840000018400000184000001040000010400000004000000040000000400000004001040000000500000001010000000000000000000000000000000000000001010000000000244000002440000000000000000001010000000000244000002440000024400000244001010000000000000000000000000024400000244001010000000000000000000000000000000000000001050000000200000001020000000500000000000000000000000000000000000000000024400000244000000000000000000000244000002440000024400000244000000000000000000000244000002440000024400000244000003440000034400102000000040000000000004000000040000000400000004000000040000000400000184000001840000018400000184000001040000010400000344000003440000000400000004001060000000200000001030000000200000005000000000000000000000000000000000000000000244000002440000000000000000000002440000024400000244000002440000000000000000000002440000024400000000000000000000000000000000004000000000000400000004000000040000000400000004000000040000018400000184000001840000018400000104000001040000000400000004000000040000000400103000000010000000400000000004E4000004E4000004E4000004E4000004E4000004E4000004940000049400080514000805140000044400000444000004E4000004E4000004E4000004E40"
