[geos-devel] GEOS-3.0.0rc1 in a week, SWIG status ?
strk at refractions.net strk at refractions.net
Fri Jul 7 15:34:38 EDT 2006
I committed a patch following your instructions.
Could you test it ?
TIA
--strk;
On Thu, Jul 06, 2006 at 08:29:01PM -0600, Michael Fuhr wrote:
> On Thu, Jul 06, 2006 at 05:27:53PM -0600, Michael Fuhr wrote:
> > On Solaris 9, gcc 3.4.2 with -ansi doesn't define int64_t (even
> > when including <inttypes.h>), and with -pedantic it warns about
> > long long.  With -ansi -pedantic -Wno-long-long it recognizes long
> > long without complaint.
> I just noticed that the conftest program is compiled without the
> options that will be used for the build.  I had edited acsite.m4 and
> changed <stdint.h> to <inttypes.h>, which resulted in configure
> finding int64_t because the conftest compile didn't use -ansi; but
> then when the build used -ansi the compiler failed, complaining that
> int64_t isn't a type.  Setting CFLAGS before the PGAC_TYPE_64BIT_INT
> tests in configure.in fixed that problem (configure then found long
> long int as the 64-bit type).
> Here's a summary of what works on Solaris 9/sparc with gcc 3.4.2:
> * In acsite.m4 include <inttypes.h> instead of <stdint.h>.
> * In configure.in, before the PGAC_TYPE_64BIT_INT tests, set CFLAGS
>   to have the same options that will be used for the actual build.
> With these changes (and after replacing a buggy libtool) GEOS builds
> and passes all tests on Solaris 9/sparc 32-bit.  I haven't done a
> 64-bit build yet.
> Michael Fuhr
