[geos-devel] GEOS-3.0.0rc1 in a week, SWIG status ?
    Frank Warmerdam
    warmerdam at pobox.com
    Fri Jul  7 15:52:14 EDT 2006
strk at refractions.net wrote:
> On Thu, Jul 06, 2006 at 10:49:59PM -0400, Frank Warmerdam wrote:
>> Strk,
>> I just tried building MapServer against the GEOS 3.0.0 C API and discovered
>> that the C API there does not seem to have all the methods for accessing
>> points on geometries that are in the 2.2.x branch.
>> I've asked Mateusz to fix this up, if my analysis is correct.
>> I hadn't noticed this before since GDAL doesn't use those extra
>> methods.
> Mm.. we shouldn't drop methods in the CAPI.
> If you can be more specific I'll check that out.
Strk,
I'm sorry, it was my mistake.  I had an old geos_c.h sitting around
in geos/source/capi and didn't realize I needed to point at geos/capi for
3.0.  No problem after all.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
