[geos-devel] Using std::vector<bool> container
Mateusz Loskot mateusz at loskot.net
Mon Jul 10 03:13:41 EDT 2006
I found this old message unreplied, so here I give my response
with longer delay. Sorry for that.
strk at refractions.net wrote:
> Mateusz, the role of vector<bool> used there is to "tag" each
> vertex in a CoordinateSequence telling wheter or not it is going
> to be into the result. Size of the CoordinateSequence is not
> known at compile-time, and we need a random access iterator
> to couple each vertex with this information.
So, we can't used deque because it does not support dynamic resize.
Also, we can't used bitset becasue it does not support iterators.
> If we want to keep tracking JTS as close as possible I'd
> use small integers instead of bools and still use a vector.
> Does it make sense ?
Yes, vector of integers is the best and safest solution I see.
Cheers
Mateusz Loskot
http://mateusz.loskot.net
