[geos-devel] c api questions for SWIG
Charlie Savage
cfis at savagexi.com
Mon Jul 10 17:30:38 EDT 2006
> I already renamed the enum to GEOSGeomTypes.
Hmm, let me resync again then.
>> 2. Message handlers have this signature:
>> typedef void (*GEOSMessageHandler)(const char *fmt, ...);
>> Are the ... parameters ever used (I didn't see any place where they
>> were). If they are used, what are they? If not, should they be removed?
> '...' is for variable args.
Yes, I know. Is it used though, and if so, how? I'm just trying to get
the exception handler correct.
> It's the same signature of printf from stdio.h.
> I would not change this as it would break existing code.
Ok.
>> 3. Init/Finish. In SWIG I can automatically call initGEOS and install
>> the message handlers. But I don't know of a way to call finishGEOS
>> automatically. What happens if the SWIG bindings don't call it?
> In HEAD finishGEOS() is a no-op. In 2.2 deletes a GeometryFactory.
> At worst you'll leak.
Good, that should be ok I think since on unload the whole dll or shared
library will be unloaded.
Thanks,
Charlie
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20060710/6cd3321e/smime.bin
