[geos-devel] c api questions for SWIG
strk at refractions.net strk at refractions.net
Mon Jul 10 17:39:58 EDT 2006
On Mon, Jul 10, 2006 at 03:30:38PM -0600, Charlie Savage wrote:
> >I already renamed the enum to GEOSGeomTypes.
> Hmm, let me resync again then.
> >>2.  Message handlers have this signature:
> >>   typedef void (*GEOSMessageHandler)(const char *fmt, ...);
> >>Are the ... parameters ever used (I didn't see any place where they
> >>were).  If they are used, what are they?  If not, should they be removed?
> >'...' is for variable args.
> Yes, I know.  Is it used though, and if so, how?  I'm just trying to get
> the exception handler correct.
I just went trought all calls and it's never used.
But I changed to use of it:
	FUNC("%s", const char*)
You can always bail out of you get different formats then '%s', but
I suggest you use the vsprintf set of functions from GNU lib.
--strk;
